dwissl Posted October 8, 2005 Report Share Posted October 8, 2005 I can record well with the 640. I stop the recording and press play: The recording sounds fine. I press off or eject: I get an empty TOC, even if I previously made a recording on the same disc with another recorder. TOCWrite always creates an empty TOC. Tried it with five different discs, which all work fine in my other recorders. Removed the AC plug and reinserted it: No change. Do you believe, that a lense cleaner could help? I also wonder, whether I should try to get it repaired or just buy a new deck. My 640 is only three years old although I used it several hours a day.Thanks Quote Link to comment Share on other sites More sharing options...
