Operababu Posted October 12, 2005 Report Share Posted October 12, 2005 Hi I'm having the same problem with Sonic Stage 3.2 with 3 different computers 2 have XP the other has 98. I get the OMGJBOX.EXE HAS ENCOUNTERED AN ERROR... Then the program crashes. On one of the computers I(XP Pro) I get a different message "Can not use this disc as an audio disc as it was intialized in a program other than Sonic Stage" The main problem started with transferring in audio files I recorded from one of my concerts. It transfered half of the files then began the problems. Sony has told me to get a new MZRH10 so I exchanged it but the problems persist.I've updated the service Pack in XP, I've seen a thing about uninstalling CODECs but not sure which to remove. I've been hitting a wall with Sony Tech support so wondered if anyone else had an answer?Also cleaned up my registry etc. Tried every thing I can think of. Quote Link to comment Share on other sites More sharing options...
Christopher Posted October 12, 2005 Report Share Posted October 12, 2005 Welcome to the forums. I have moved your post to the software forum; please state your system specs according to the rules. You may also want to try reinstalling via the directions in the FAQ. Quote Link to comment Share on other sites More sharing options...
