frankienap Posted October 18, 2005 Report Share Posted October 18, 2005 Hi everyone, I want to thank this forum so much for all the advice and help which I've received from you all over the years. I am now the very proud owner of a Sony mz-rh10! I am, however, terrified that my baby will become scratched. So, I made a template for a screen protector. It is custom fit (to my unit at least) to fit over the entire clear-plastic section, with cutouts for the control buttons. Any clear adhesive material (screen covers, contact paper) should work well.It took me a while to get the dimensions right, but I think it should work. Anyone wishing t to make any improvements, email me and I'll send you the .psd file. However, I am posting a pdf file for everyone to use.-Frankmz_rh10_template.pdf Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted October 18, 2005 Report Share Posted October 18, 2005 Thnaks for that. I find the screen protectors peel off too easily, so nowadays I just cut out a small rectangle for the screen. The rest of the face isn't too badly scratched (yet), as the RH10 is mostly cased up, so hopefully that'll be enough to keep it in good condition... Quote Link to comment Share on other sites More sharing options...
ynos Posted October 18, 2005 Report Share Posted October 18, 2005 So, I made a template for a screen protector. Is this screen protector you used the same as the one use for PDA? Quote Link to comment Share on other sites More sharing options...
frankienap Posted October 21, 2005 Author Report Share Posted October 21, 2005 I used a translucent contact paper (with adhesive backing) that I picked up at the paint store, it works really well. It's not as clear as the player w/out any protector, but it's a perfect fit and I can now walk around town with the player in my pocket not having to worry about it getting scratched. Quote Link to comment Share on other sites More sharing options...
md-rocks Posted October 25, 2005 Report Share Posted October 25, 2005 what a coincedence, i was just thinking of making a cover for my rh910 myself...but you saved me alot of trial and error!! thanxs alot for the template..much appreciated!!what i use to make it from your template is a belkin pda protector # F8E712 for palms 3-7... i only cover the clear plastic part of my rh910cause that the part i feel will be prone to scratches...the other half is part of the body...but its your choice if you wanna protect the entire face which is cool as well... so what i did was measure the template along the part i want covered cut the template in half then tape the template on the pda plastic label sticker and cut around it...tip..when placing it on your unit sure you do it nice and evenly or you mayend up witha few air bubbles...hope this helps as well....thanxs again FN.... Quote Link to comment Share on other sites More sharing options...
