RICHZ6 Posted October 27, 2005 Report Share Posted October 27, 2005 Equipments: SONY MD: MZ-N10 (BRAND NEW)PC: P4 1.5 +512RAM + XP SP1 Problems experiencing: With the write-protect tab flicked off at all time. (This means no see through the tab hole right?)1) When not connected to PC through USB and a blank minidisk is inserted: Device reads the minidisc forever and displays BUSY2) When connected to a PC thorough USB: PC (both in device manager and Sonic Stage 1.5) does not recognize the MD device if a blank minidisc is inserted and the device displays PC--> MD. Only recognize the device when a blank minidisc is not inserted.3) After recording from line-in the MD will end up showing "SAVE DATA" forever.Question: Is my SONY MD’s problem related to a recording wire issue similar in posthttp://forums.minidisc.org/index.php?showtopic=4712 titled "A Solution to Blankdisc and Recording Problems."If not, please help me thank you very much in advance as I have been struggling for months now. Quote Link to comment Share on other sites More sharing options...
zerodB Posted October 31, 2005 Report Share Posted October 31, 2005 Sounds like a hardware issue. If the unit is under warranty, take it back. Quote Link to comment Share on other sites More sharing options...
dconnol1 Posted November 29, 2005 Report Share Posted November 29, 2005 Sounds like a hardware issue. If the unit is under warranty, take it back.I have just purchased one of these - same problem - when transferring from PC to MD it gets to 95%, stops and displays DATA SAVE forever, must be a common fault - any ideas? Quote Link to comment Share on other sites More sharing options...
