travis Posted November 5, 2005 Report Share Posted November 5, 2005 I'm tryin to load SonicStage 3 and it wont create a program. Makes a folder for it...but no program. All that loads is the simple burner thing. anyone help me out? Quote Link to comment Share on other sites More sharing options...
travis Posted November 10, 2005 Author Report Share Posted November 10, 2005 ?? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted November 10, 2005 Report Share Posted November 10, 2005 Could you please be more specific? For example, which version of SonicStage 3.x you were trying to install. In addition, it is important to state your system specs and most important, try reading the Hi-MD/NetMD Software FAQ for possible solution. Please be patient and someone on board will provide assistance shortly. Quote Link to comment Share on other sites More sharing options...
travis Posted November 11, 2005 Author Report Share Posted November 11, 2005 i was tryin to install either version 3.2 or 3.3. I tried using the disc that came w/ the mindisc and the versions you guys put up. And i did follow that solution thread but still no go.One thing it said is that it wont work if you pc was built...which was the case for me. So i'm assuming thats why. Is there anyway around this? Or is there a older version that would work? The computer i have is:Microsoft Windows XP proVersion 2002Service Pack 2Athlon 64 Pross1.81 Ghz 512RamAnd thanks for all your guys help here on the boards...its great Quote Link to comment Share on other sites More sharing options...
A440 Posted November 11, 2005 Report Share Posted November 11, 2005 Older versions are less stable and do less--the crucial thing about 3.2 and 3.3 is that they allow infinite uploads. It wouldn't hurt to try this: Uninstall (with Add/Remove Programs) and clear out the registry as in the FAQ, and download the offline 3.2 installer. Install that with your computer disconnected from the internet and all antivirus and firewall software turned off. (Put them back on before you go back online.) Do it without the unit connected via USB. Maybe some security program has interfered with the install. Quote Link to comment Share on other sites More sharing options...
