Panasonic's 2003 MD-boombox
Mikami
This is Panasonic’s 2003 “personal MD studio” just their fancy name for a MD/CD/Cassette cute boom box. People other than Panasonic usually call it MD/CD Ra-ji-Ka-se. It comes in “white/green” and “silver/blue” colors.
The major neat ability of this unit is:
MD-NETWORK function
The MD-NETWORK function allows one to hook up their portable MD unit and transfer both audio tracks and song titles data as well. The Unit can also tilt on its stand. That is more a cute or neat ability than anything, else.
The normal abilities are:
1. Speed recording from CD to MD (6X)
2. Recording from tape to MD, from MD to tape, CD to tape, from radio to tape or MD.
3. MDLP and standard SP recording modes
4. Unattended timed recording of radio to tape or MD. The unit can be set to record from any time period just like one does with a VCR.
5. The unit can be set to start playing for any timed period and also to turn it’s self off.
6. AM/FM Radio and ability to play audio from T.V. stations
7. Preset mode(PGM)
8. Live Virtualizer (L.V.)
9. Sound EQ (Heavy, Clear, Soft, Vocal, and EQ-off)
10. Speaker Position Selector (20°~60°, 50°~80°)
11. sleep button
12. scan/group/skip
13. Displays the name and station number of FM/AM and TV.
14. has some type of back up battery for it’s clock and settings
15. one can hook up external units and listen to their MD portable units, old record player, or anything else that uses the Panasonic “RP-CAPM3G15(pin mini cord) analog/stereo red/white plugs on one end and a single plug on the other, RP-CAM3G15(mini-cord)line in/line out one plug on both ends, and the RP-CAMC9G15(MD-NETWORKcord). http://prodb.matsushita.co.jp/product/info.do?pg=04&hb=RP-CAMC9G15
On, the back of this unit one will find:
1. P-MD/AUX jack
2. MIC MIC jack
3. Head phone jack
4. Extra AM ant jack
5. Typical FM ant
6. AC jack
7. A place to clip the AM ant
It comes with:
1. Remote(EUR7711090) and batteries
2. Power cord(RJA0012-k)
3. AM ant (G0ZZ00002036)
4. Manual (RQT7127-6S)
More information can be found at:
(1) http://www.minidisc.org/part_Panasonic_RX-MDX81.html
(2) http://prodb.matsushita.co.jp/product/spec...=06&hb=RX-MDX81
[attachmentid=1162][attachmentid=1161][attachmentid=1160]
[attachmentid=1159][attachmentid=1158][attachmentid=1157]
[attachmentid=1156][attachmentid=1155][attachmentid=1154]
[attachmentid=1153][attachmentid=1150][attachmentid=1151]
[attachmentid=1152][attachmentid=1149]
This unit has been waking me up in the mornings with nice tunes for along time. One day, I hope, there will be a nice HI-MD boom box like this one or better. Till, then I will keep using this unit esp since I can hook up my HI-MD unit through the P-MD/AUX jack.
regards,
Mikami
Edited by Mikami
