zep_tepi Posted November 23, 2005 Report Share Posted November 23, 2005 Easy goin guys!hope alls well - i just wanted to say hello and stuff ive got a tough little mini-disc walkman - a Sharp IM-DR400 (a beast of a machine IMO!) and has given me many years of quality playback. However im still stumped to the claim on the machine of the 1bit technology.How does this affect the sound?Ive also got a 4pole connection jack which separates the sound (or something) but it sounds tinny and really bassless, which is awful - But am i utilising it correctly?Any thoughts on this would be well appreciated, as everyone i ask has gone digital cheers!ZEP Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted November 23, 2005 Report Share Posted November 23, 2005 Hi. I've got the IM-DR420, which is very similar to your DR400 (only difference is the mic in and remote I believe). The 1 bit refers to Sharp's own 'Auvi' digital amp which is meant to be more efficient and cleaner/clearer than a normal amp. This might be the tinniness you're hearing, as Sharps amps are usually swamped with bass. The 4 pole is supposed to give better stereo separation, though this claim is somewhat dubious. Overall though I'm quite pleased with the Sharp's sound, though really I like the typical Sony sound a wee bit more.Have you tried using the equaliser to modify the bass and treble settings - I've found that helps... I've only used the stock buds with the DR420, but there are some Sharp 4-pole headphones that are supposed to be good. You can also use normal 3-pole phones too, but thereby won't get the benefit of the 1-bit sound. Quote Link to comment Share on other sites More sharing options...
zep_tepi Posted November 23, 2005 Author Report Share Posted November 23, 2005 Hey alright! Thanks KJ! Looks like ive come to right place to start getting some answers..!Ive checked out the link you provided and it helped big time.I got another question :Do you have an OPTICAL OUT point on your unit?If so - whats the difference betwen using this and using the USB device (not sure if you have this on yours)I mean is there a difference in sound quality or speed or compression when it comes using this port?cheers!ZEP Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted November 24, 2005 Report Share Posted November 24, 2005 Hi. Well, yes I have CD and MD decks with optical out. This connection gives better results than 'downloading' to the DR-420 via USB, but the drawback is that you have to record in real time. Having said that, I do most of my CD-MD recording via a special deck (MXD-D40) which also gives superior results.One point to note is that if you use the USB connection to record you can only achieve a maxium of LP2 quality (132kbps), though that's fine for most people... Quote Link to comment Share on other sites More sharing options...
zep_tepi Posted November 24, 2005 Author Report Share Posted November 24, 2005 Thanks again KJ.I dont have a deck as speacialised as yours is - i just gotta go outta my PC via USB and into the unit itself.(Im still in the stone age dude!!) Last Question:Do you know where I could get my mits on an optical out for this unit and also a set of headphones which fit the special rectangular port (I think most IM-DR models have this?),Cheers!ZEP Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted November 24, 2005 Report Share Posted November 24, 2005 You're welcome, Zep Bad news, I'm afraid there are no optical outs for these units. Only full size decks have them (the more expensive ones too, like the Sony MDS-JB980).Also, I'm not sure what you mean by the rectangular port - do you mean the remote control port? The headphone would plug into the other end of the remote. You may be able to order a suitable remote from Sharp's website, or one may turn up on ebay. You should get one specially for 1bit/Auvi units as the normal 3-pole Sharp remotes won't work properly... Sorry, but I'm using mine... Quote Link to comment Share on other sites More sharing options...
zep_tepi Posted November 25, 2005 Author Report Share Posted November 25, 2005 Cool as - Ive been lookin of ebay and come across some interesting offers out there.Even and optical out lead...Now i just gotta think about getting the dough for one o those decks...Cheers!ZEP KJ_Palmer said: Sorry, but I'm using mine... if you ever find it to be a burden - you know who to call... Quote Link to comment Share on other sites More sharing options...
boxer786 Posted March 1, 2010 Report Share Posted March 1, 2010 please help do you have the drivers for the minidisc netMD usb driver for the DR420 minidisc or similar? so i can downlaod it and use sonic stage or beatjam? please please help- i have been looking for it for 12 hours please email it to baid@live.co.uk i will be forever grateful Quote Link to comment Share on other sites More sharing options...
