Problem: My MD doesn't record anymore!
bachaka61
Hello,
I've had my Minidisc player since 2002... That makes it 3 years now....
Anyway, it was working perfectly, till last week. I was transfering some tracks to my MD using RealOne player, and finished. Everything looked perfect.
When I was in the bus, I pressed "play", and I could'nt hear anything, and the time elapsed would stop at 5 seconds. Then I was like "What the...?" ... I recorded like 22 tracks on the MD... Then I press "stop" then the MD shuts off...
A minute later I press "play" and it shows "BLANK". I could'nt believe it... Anyway... I tried another previously recorded MD and it worked perfectly along with others.
Back home, I recorded another blank MD using RealOne player... Everything looked ok, but when I pressed play, nothing worked, and the MD went BLANK afterwards.
I don't understand. Can someone help? My MD reads minidiscs well, but it does'nt work when I try to record....What should I do?
Welcome to MDCF!
What's the model # of your MD unit? From your description, it seems that your unit's optical block has expired. You basically have two options hereafter: send it to your local Sony Service Center or acquire a new recorder.
My model is a gold MZ-N505 ... Why has my optical block expired?
