spongebob08 Posted November 28, 2005 Report Share Posted November 28, 2005 (edited) Hi !I was using SS3.0 without any problems and i just go with SS3.3When I play songs in it a horrible noisy song keep playing over the bass of the music. Even if the volume is down. I have no problems listen to my mp3 with iTunes,winamp,wmp. And the noisy sounds keep staying on the music when it is convert in ATRAC...I really do not understand.Please help.P.S : sorry for the bad english. Edited December 5, 2005 by spongebob08 Quote Link to comment Share on other sites More sharing options...
Christopher Posted November 30, 2005 Report Share Posted November 30, 2005 Welcome to the forums. Is this happening to all of your mp3's? What kind of bitrate are the mp3's encoded in? You may also want to post your system specs according to the rules. Quote Link to comment Share on other sites More sharing options...
spongebob08 Posted December 1, 2005 Author Report Share Posted December 1, 2005 Thx,It happens when the mp3 have full bass. When the mp3 have not many bass the song is not so disformed. And for the bitrate...it do that with all....96kb->192kb. I have Windows XP professional SP1 with all security and som others update.My computer is a:XP2600+1024 Mo DDRSoundblaster 1024.and lot of memory space! Quote Link to comment Share on other sites More sharing options...
spongebob08 Posted December 5, 2005 Author Report Share Posted December 5, 2005 HI !I found the solution ! It was a codec problem. I have just renamed the "iviaudio.ax" in something like "iviaudio.bak" and now I can normally listen to the music with SS3.3 ! Quote Link to comment Share on other sites More sharing options...
imagine Posted December 6, 2005 Report Share Posted December 6, 2005 I experience this problem too with SS3.3... where is this codec located? I can't seem to find it. Quote Link to comment Share on other sites More sharing options...
dodobird Posted December 7, 2005 Report Share Posted December 7, 2005 the file is in the windows\system32 folder.just wanted to thank the finder of the problem, you have NO idea how much you helped- i nearly had a nervous breakdown because of the problem Quote Link to comment Share on other sites More sharing options...
spongebob08 Posted December 10, 2005 Author Report Share Posted December 10, 2005 You're welcome ! I found the solution on a french forum. Generally, we, french have bad forum, that's why i was here, looking for a solution. Finally I found the solution on the first forum i was.Thx a lot ! Quote Link to comment Share on other sites More sharing options...
obsidianrock Posted January 4, 2006 Report Share Posted January 4, 2006 I am having the same problem but I can't seem to find the "iviaudio.ax" file you mentioned. You said it was in the windows>system 32 folder?Please Help! Quote Link to comment Share on other sites More sharing options...
sebastianbf Posted January 4, 2006 Report Share Posted January 4, 2006 (edited) hey spongebob ne disparaissent. keep posting ici! Welcome Edited January 4, 2006 by sebastianbf Quote Link to comment Share on other sites More sharing options...
obsidianrock Posted January 4, 2006 Report Share Posted January 4, 2006 I have no idea what that means. Quote Link to comment Share on other sites More sharing options...
jaradthescot Posted January 6, 2006 Report Share Posted January 6, 2006 I'm having trouble here too, can't find that codec... Quote Link to comment Share on other sites More sharing options...
obsidianrock Posted January 6, 2006 Report Share Posted January 6, 2006 I couldn't find the one they were talking about but I found one named "Ac3audio.ax" and I changed the file extension to "Ac3audio.bak" and it seemed to work for me, give it a try Quote Link to comment Share on other sites More sharing options...
Clarky Posted January 10, 2006 Report Share Posted January 10, 2006 I must thank Obsidianrock, his method solve the problem for me, and spare me other sleepless nights! Sonicstage seems to work properly now, but for how long? Quote Link to comment Share on other sites More sharing options...
nicknster Posted February 8, 2006 Report Share Posted February 8, 2006 I must thank you as well. I registered an account just to thank you. I did quite a bit of searching to find the solution. I recently had to reformat and I updated from 2.0 to 3.4 and I started having this problem. Worse yet, when I tried to go back to 2.0 the problem persisted. What the hell is this file for? Why don't they fix it.Thanks again. Quote Link to comment Share on other sites More sharing options...
Wolfrunner6996 Posted March 17, 2006 Report Share Posted March 17, 2006 thank you so much, the sound issue with the sonistage was driving me mad, I really apprectate the help!! Quote Link to comment Share on other sites More sharing options...
