Hooking up Pro mics to a HiMD
FPK
How do you experienced users connect pro mics to your HiMd's? By pro I mean something like a Sennheiser K6/ME series that has a battery powered phantom power unit in it. If I hook this up to the mic line-in, will it work? What sorts of outboard boxes do you use to hook up pro mics that don't have phantom power? Has anyone tried a Sound Devices MixPre with a HiMD? Did it make a difference? Is it overkill?
Thank you,
FPK
Here I can use a Sennheiser MZA-MS preamp with my Sennheiser MKH series mics if I need to - I connect the output from the preamp (XLR connectors) via an adapter cable which is quite simple to make up - just buy a lead such as 2 x RCA phone to 1 x stereo miniplug, chop off the phono plugs and solder on XLRs. That avoids having to do battle with soldering the tiny stereo connector - XLRs are easy, and some solderless designs are available too. Obviously it goes into the MD's line in socket, as it's a line level signal from the preamp.
Here you can find some cable's to hook up professional dynamic mics to your MD:
http://www.mdcenter.nl/artikelen/mdcpro/kabels.php
And here a very cheap DIY phantom power supply for non-dynamic mics:
http://www.mdcenter.nl/artikelen/mics/portablephantom.php
Off course all proposed cables and circuits I used myself to make recordings and they work perfectly!
P.s. I just put the portable phantom-power in a box. It is not realy compact but hey, neither are most professional mics:
IPB Image
Edited by MDfreak
