Connect Store Registration Problem
ajwhitehead
I have had a very similar problem 'ajwhitehead' in that when i try to use Connect to register, i wait a while, then a screen comes up asking me to verify my connection...which i know is present. I have now registered using IE by going to www.connect.com. This does work.
I think the only reason for registering is so that Sony have some of your details in the hope you will use Connect store in the future, and so you can log in and out of their website. According to this forum: http://www.atraclife.com/index.php?showtopic=730 it would seem like you only need the serial number of your NWA and a speical number that came in the box to get the free album, once you have registered.
I will now try getting an album and seeing if this works, hope the above works, and I will report back with the outcome later.
