pburress Posted December 16, 2005 Report Share Posted December 16, 2005 My MZ-R700 is messing up in recording- I recorded some live music, now it says Disk Error... It reads exising disks but if you try to record it will mess up the disk so it generates the Disk Error message. I've read about this problem and plan on replacing the unit. Currently I am trying to clone the TOC on a disk using my freind's MZ-N707 unit. I cannot find the switch or sensor that tells the unit that the door is open. any clues as to where this is on this unit, and what do I need to do to tape this down or otherwise disable it? I'm hoping I won't have to take it all apart!Thanks in advance!Phil Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted December 16, 2005 Report Share Posted December 16, 2005 It might be in the service manual:http://www.minidisc.org/part_Sony_MZ-N707.html Quote Link to comment Share on other sites More sharing options...
pburress Posted December 16, 2005 Author Report Share Posted December 16, 2005 Thanks, I'll check that out. If anyone has any experience with TOC cloning on this particular model I'd appreciate some input. Can I do the TOC Cloning using service mode instead of disabling the disk open sensor? Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted December 16, 2005 Report Share Posted December 16, 2005 To be honest, I have never heard of TOC cloning done on portables. All the guides I have ever seen have been for decks. Quote Link to comment Share on other sites More sharing options...
