In need for CMT-C7NT NetMD driver for WinXP EN version
incvn03
I need driver netmd CMT-C7NT on windowxp pro english , help me ! thanks
Welcome to MDCF!
The NetMD driver for the CMT-7NT is included in its bundled OpenMG Jukebox v2.2 CD-ROM and its PCLK USB Driver should reside within its included M-Crew CD-ROM. Do you have both the bundled software? If you do not have it, please download the NetMD driver from this thread and the Sony PCLK USB Driver for XP here --> *attachment removed --> please download it from the download section. Please let me know if it works.
*I forgot to add that the PCLK USB Driver for XP is of Japanese version. But you should have no problem installing it onto a WinXP Pro EN system.
Edited by Ishiyoshi
Welcome to MDCF!
The NetMD driver for the CMT-7NT is included in its bundled OpenMG Jukebox v2.2 CD-ROM and its PCLK USB Driver should reside within its included M-Crew CD-ROM. Do you have both the bundled software? If you do not have it, please download the NetMD driver from this thread and the Sony PCLK USB Driver for XP here --> [attachmentid=1245]
okei, thank Ishiyoshi for quick reply, i downloaded and install flow :
1. install Sony PCLK USB Driver for XP for cmt-c7nt pc recognize sound card usb
2. install netmd driver, i very happy. windows xp recognize netmd cmt-c7nt when i press button on netmd and plug usb conected pc and netmd cmt-c7nt.
3. unplug usb netmd and install openmg 1.2 and update openmg 2.2 , and retart computer, but when i conect ubs netmd to pc and run openmg 2.2 , openmg said not found external media, netmd not present on openmg
i try install mcrew 2.01E but not use netmd cmt-c7nt on openmg
why ?, can you help me !
thanks
Edited by incvn03
thanks
I'm glad the attached Drivers works for you. As for M-Crew 2.01E, ensure that it is for the CMT-C7NT - all other version may not work with the CMT-C7NT (The CMT-C7NT comes bundled with M-Crew 2.01E for CMT-C7NT). Meanwhile, you should install SonicStage 3.3 and try it with the CMT-C7NT. My own unit is in storage, so I can't confirm its compatibility with SonicStage. Nonetheless, please report back.
I might be able to offer some help too - I have the 333NT - a similar unit.
As far as I recall there are three drivers needed for the unit to fully function:
- Sony PCLK Driver (for unit operation with M-Crew)
- Generic USB Audio Codec Driver (for playback of PC audio on your hi-fi)
- NetMD Driver for your unit (for use with SonicStage/MD Simple Burner, etc)
As Ishii pointed out, the version of M-Crew is specific to your unit, so the one from the M-Crew website won't work.
I can confirm that all OpenMG compliant software (SonicStage and MD Simpleburner, etc) functions perfectly with the 333NT, once the NetMD drivers are installed. However, you cannot use M-Crew and OpenMG compiant software at the same time.
Glad to hear the NetMD part seems to be working. The latest SonicStage should work fine for you I presume. Does M-Crew work for you now?
ok thank all, cmt-c7nt very cool with sonic gate3.3,
I'm very happy join in MDCF, I'm from Vietnam.
1. remove all software and driver for netmd
2. install usb driver
3. install netmd driver
4. install sonicgate 3.3
and restart, run sonicgate ----------------------------> ok
Brilliant! I'm glad that it works. Enjoy your stay with us. :)
