PowerShot Posted December 28, 2005 Report Share Posted December 28, 2005 I have litle over 21 cd on Connect Player for now. But now I plan to reinstall window. Wich files is importent to copy so that I dont have to rip and catagories all this cd again. I just want to have it just like now, after an reinstall. I also have extra hardisks to store on.-Windows xp pro.-Connect Player with the newest update.-Sony NW-A3000, firmware 2.01. Quote Link to comment Share on other sites More sharing options...
C_player Posted December 29, 2005 Report Share Posted December 29, 2005 PowerShot said: I have litle over 21 cd on Connect Player for now. But now I plan to reinstall window. Wich files is importent to copy so that I dont have to rip and catagories all this cd again. I just want to have it just like now, after an reinstall. I also have extra hardisks to store on.←Assuming you've saved all the information in the files you ripped, and you didn't move them from the original install location, your music can be found here (on most standard XP PCs):C:\Documents and Settings\Username\My Documents\My Music\If you made changes to the Connect player path, it put them wherever you set the path to. Check your preferences, CD ripping settings for more information. Quote Link to comment Share on other sites More sharing options...
PowerShot Posted December 29, 2005 Author Report Share Posted December 29, 2005 (edited) The ripped cd is on an extern hardisc. So I told Connect Player in preference to store the ripped cd there.Are there no need to backup, or take a copy of "C:\Document and Settings\All Users\Application Data\Sony Corporation\CONNECT Player\Library"?Or just take backup, or copy "C:\Document and Settings\All Users\Application Data\Sony Corporation"? Edited December 29, 2005 by PowerShot Quote Link to comment Share on other sites More sharing options...
C_player Posted December 29, 2005 Report Share Posted December 29, 2005 PowerShot said: Are there no need to backup, or take a copy of "C:\Document and Settings\All Users\Application Data\Sony Corporation\CONNECT Player\Library"?Or just take backup, or copy "C:\Document and Settings\All Users\Application Data\Sony Corporation"?←You shouldn't have to do anything with the library files or any of the other directories the player leaves behind. Simply install the player on your clean XP, re-scan or import your files, and everything should return to normal.If you feel overly cautious, you could backup that whole Sony Corporation directory, but I don't think you'll need it. Quote Link to comment Share on other sites More sharing options...
