Link for SS 3.2
englebert
Does anybody know of a link where I can down load a version of sonic stage 3.2. Since upgrading to 3.3 I have had nothing but probelms - an inability to transfer more than one album in a single instance unless I wipe the disc. Problems with editing uploaded files, problems on occasions with deleting multiple groups. Everything worked fine until I moved to SS 3.3. :angry:
I have re-installed SS 3 times following the guidance within this forum, twice using the official UK Sony link, the third time using the self contained package from this site. The latter did improve things, but I still have problems. :wacko:
:wacko:
If I could ask this question too. I have raised the same issue under a different thread (oranges - "Getting started")and although someone replied saying they had experienced no problems with version 3.3, the question of where I can download version 3.0 or 3.2 is yet to be answered. I too have the MZ-NH900 and I think version 3.2 (and possibly 3.0) will be more than adequate for my needs. I have Windows XP Service pack 2 on a new relatively clean machine. Although I have not experienced installing version 3.3 from what I have read it seems more trouble than it is worth.
For info, I do not have any version on my machine to uninstall as I was running version 2.0 on an old machine and this has been uninstalled on that machine.
Thanks in anticipation.
I don't think SS3.3 is more trouble than it is worth. I say try it, see what you think, and if it really flukes up for you then revert to 3.2. englebert, I have sent you a PM with a d/l link.
OK. Thanks. Will try. If however it does cause problems and I want v3.2 then I will come back and ask for the download link as you have sent to englebert if that's OK.
