Recharging problem on MZ-M100...
Berke
Hi,
I don't know if this is the right part of the forum for my question but I cannot seem to charge the battery on my new M100. I install the battery correctly as the manual says, then I plug the AC and press the stop/charge button, as the manual says, and there is no response from the unit. Whatever I do, it goes directly to the AC mode, when I unplug, it starts showing the battery meter, which I presume starts using the batteries only then.
Did anyone who has M100 encounter this peculiar behavior?
I'd appreciate your helps,
Thank you...
  • 4 weeks later...
