MZ-N10 problems
sonder
Hi all,
This is the first time I'm posting here, but I think this is the inly place that can help.
I've had a MZ-N10 for around 2 years now, and I've never dropped it, spilt anything on it etc.
Now everytime I place it in the cradle it charges fine, but is not recognised by sonicstage and also everytime I try to playa minidisc the disc just spins and makes a churning noise. I can select different tracks, but nothin plays it just keeps spinning. When I eject the disc it's still spinning for about half a second. Finally I've used a minidisc head cleaner and it didn't work, please help, I can't afford an ipod or pvp at the moment.
Sonder!!!! :huh:
  • 3 weeks later...
I do have the same problem as you with the same minidisc unit.
Mine gets itself blocked after I take it off the cradle and shows PC>MD whenever I try to press a button. I have to reset it by turning the battery off and on.
No one was able to explain to me the cause for this sudden malfunction. It used to work beautifully before.
