Is there a button to enable gapless play?
Henrys
2 answers to this question
With the latest firmware gapless is automatic. The key is that the file format you're using must be gapless as well: Atrac3plus is gapless, however, mp3 is not. If you're listening to MP3s, there's likely to be at least a small gap between your songs. Ripping a CD in Atrac3plus in Sonic Stage should do the trick for you, as far as gapless is concerned.
