apropos Posted February 6, 2006 Report Share Posted February 6, 2006 (edited) I've just upgraded from SS 3.2 to SS 3.4 and I can't find the option of automatically deleting files from HiMD's after they have been transferred. I think SS 3.2 had some menu under "Device/Media" where you could UN-check the box saying "leave tracks on media after transferring" but I don't see anything like this in SS 3.4.P.S. As the description suggests, the option to "delete the converted files from the hard disk after transferring" is not what I'm looking for: I want to do the opposite - delete the files from the HiMD media, not the hard drive. Edited February 6, 2006 by apropos Quote Link to comment Share on other sites More sharing options...
Killroy Posted February 6, 2006 Report Share Posted February 6, 2006 apropos said: ... automatically deleting files from HiMD's after they have been transferred. ...Even if it existed, I'd strongly recommend NOT to use such an option ever. What, if SonicStage messes the upload but succeeds deleting the source "automatically" - a source like a live recording that you cannot repeat for example?Better you upload, check if it worked OK, export to WAV, preferrably on different media, and THEN delete the source from the disc if you want to...Cheers - Killroy. Quote Link to comment Share on other sites More sharing options...
raintheory Posted February 6, 2006 Report Share Posted February 6, 2006 The only option I remember was the "Delete converted files from the hard disk after transferring". Which would just prevent SonicStage from cluttering up your hard disk with converted Atrac3+ files... Quote Link to comment Share on other sites More sharing options...
