Error Message in SS 3.4!
Berke
Hi All,
I just downloaded and installed SS 3.4, looked fine initially, until I decided to import my music folder that is.
Here I received the error message maye 5 or 6 times. Is there any explanation to this? After I clicked OK and continued, everything is alright. But if I were to start importing and leave the room, I would be much frustrated I guess.
I think it imported all my music, but I can't be sure if it did all the files.
What does it mean?
IPB Image
Edited by Berke
This may be unrelated, but I have seen SS complain if you try to import a folder with lots of subfolders but no valid audio tracks in either the 1st or 2nd branch of the tree. Yes, it's weird.
I tend to just drop my "music" folder straight on the library and let it do its thing, it works fine every time. The actual search tool can behave oddly at times.
