tapa Posted February 8, 2006 Report Share Posted February 8, 2006 hello gents,I would like to by sony rh10 but somewhere a read that are difference between US version and europe version, it's true. Exist some possibility how to upgrade europe version?thxtapa Quote Link to comment Share on other sites More sharing options...
Roamer Posted February 8, 2006 Report Share Posted February 8, 2006 (edited) The european version has volume output and EQ restricted, but this can be hacked if you want. Edited February 8, 2006 by Roamer Quote Link to comment Share on other sites More sharing options...
tapa Posted February 8, 2006 Author Report Share Posted February 8, 2006 The european version has volume output and EQ restricted, but this can be hacked if you want.Great and do you now how to hack it? If you hack this, what will happen with your warranty? Will be still valid?Thank Quote Link to comment Share on other sites More sharing options...
Roamer Posted February 8, 2006 Report Share Posted February 8, 2006 It's on the pinned topic :http://forums.minidisc.org/index.php?showtopic=9752If you want to try, beware to follow the instructions carefully, as changing the wrong value could render the unit useless. You do so at your own risk. Quote Link to comment Share on other sites More sharing options...
tapa Posted February 8, 2006 Author Report Share Posted February 8, 2006 thanks a lot Roamer.tapa Quote Link to comment Share on other sites More sharing options...
