Sony ECM-DS70P mic
Smafie
Hello guys..
I have a question about the Sony ECM-DS70P mic and 'Plug in Power'. It may seem like a stupid point but bear with me :unsure: ..
As i understand it Plug in Power is varies from 1.5v to 10v, but can anyone tell me if this mic was used in a Phantom Power connection, ie 48v, would it work or simply blow it up!! I normally use it with the MZ NH900 for field work but wondered if i could adapt it for my bigger Tascam unit.
Thanks
Steve.
This mic is not designed for phantom power, so i guess you would end up with a fried mic ...
The technical specification should tell you when a mic support phantom power (and not many support both phantom and 9V).
EDIT : Read also this thread
http://forums.minidisc.org/index.php?showtopic=14188
Edited by Roamer
Hey thanks.
I kinda thought that would be answer somehow, but just didn't know the technical aspects of phantom power and plug in power, even though one's instinct suggests that something 4 times the voltage is not exactly healthy!!
Guess i'd better start saving for a new mic then, for the Tascam i mean..
Cheers
Steve.
