Another ATRAC test!
dutchtrance
hey guys!
wondering if you can help me out with a lil project i`m doing.
i`ve taken a tune i like ( public domain - Luv you more ( That mucho remix ) ) and digitally ripped it from the cd.
i`ve edited the wav, but not applied any filters.
i`ve then encoded it into one of the formats below.
you`d know the format if you knew the extention etc, so i`ve decoded the file to wav, but the file was a little large so then losslessly encoded it to ape.
i`ve made a list of what file number is what codec and uploaded the ape files for you to download.
i used 192 bit rate as this usually provides a good standard between sound quality and file size.
the codecs i`ve used are -
CBR MP3
OGG
AAC
WMA
Atrac3plus ( encoded via connect and decoded using hma render )
Atrac SP type R ( encoded optically using MD deck and optically recorded back to PC )
VBR WMA
MP3
OGG
WAV WAV
so heres the plan
Download either APE decompressor ( www.monkeysaudio.com/ ) and decmpress the APE file to wav or find an APE DLL for foobar/winamp etc and play the native APE file.
try to make sure there are no EQ`s running or enhancement programs.
Right click one of the numbered files below and download
Listen to the whole sample
give it a mark out of 5 ( 1 being bad artifacts 5 being perfect ) and any comments on the file.
email me the results ( paulv@paulv.dj ).
please do not post the results below as this may influence other people`s views of the sound quality.
i`ll publish the results later so every one can see
the files are about 10 megs each becouse of the wav format so might take a bit to download and listen to each one, but i`d be very happy if you could
thanks a lot
File1
File2
File3
File4
File5
File6
File7
File8
File9
File10
