Inserting music into playlist without re transfering?
videot
As you work you can add more tracks to your playlist & these get added to the bottom of the list. I understand that you can work on the list & drag them around to change their sequence. As you know you can create your playlist & transfer at the same time.
What I'd like to know is if you have transferred the tracks as you go & then decide what you wished to insert another album in somewhere near the top of the list can you do this without erasing the disk & transfer everything over again?
