PowerShot Posted January 4, 2006 Report Share Posted January 4, 2006 (edited) After I defrag hardisk with diskeeper 9, connect player wont work. When I click on rip nothing is hapend. The only thing is that where you before clicked rip you have an option to "quit this action". Nothing hapend if you click on it. This hapend every time. I reinstall connect player, and it work. I defrag it dos not work.Window xp proI have the newest update to connect player: Connect Player version 1.0.02.11170. Auto-Update version 1.0.02.11150. Edited July 26, 2006 by Ishiyoshi Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 4, 2006 Report Share Posted January 4, 2006 Have you tried to Defragment your hard disk with Windows in-built" "Disk Defragmenter"(I know it`s slow )..I think Diskeeper might be doing something silly with Connect player files . Quote Link to comment Share on other sites More sharing options...
PowerShot Posted January 4, 2006 Author Report Share Posted January 4, 2006 Stuge said: Have you tried to Defragment your hard disk with Windows in-built" "Disk Defragmenter"(I know it`s slow )..I think Diskeeper might be doing something silly with Connect player files .I have not encounter this problem with any of the other program when using diskeeper 9. I have not tried windows in built disk defragmenter. Maybe I should try that, when I go to sleep. Is there any one else with the same problem, and that have tried the windows in built disk defragmenter? Quote Link to comment Share on other sites More sharing options...
