VanJay011379 Posted March 14, 2006 Report Share Posted March 14, 2006 Hi,I have a minidisc that was scratched in my pocket. The disc inside the plastic is actually scratched and skips.Is there anyway to buff this out? I have a disc doctor for my CDs. How can I buff the disc inside the plastic case? However, is the minidisc disc more fragile?Any suggestions?Cheers,Chris Quote Link to comment Share on other sites More sharing options...
MDfreak Posted March 14, 2006 Report Share Posted March 14, 2006 Throw away the disc and buy a new one.MD-discs are totally different from CD's. Also most of the disc-cleaner products are meant for CD-R and not for recordable media. Furthermore it is almost impossible to remove the disc from the casing. Quote Link to comment Share on other sites More sharing options...
VanJay011379 Posted March 15, 2006 Author Report Share Posted March 15, 2006 MDfreak said: Throw away the disc and buy a new one.MD-discs are totally different from CD's. Also most of the disc-cleaner products are meant for CD-R and not for recordable media. Furthermore it is almost impossible to remove the disc from the casing.I had some live recording on it. Hence, I don't want to just throw it away. Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted March 15, 2006 Report Share Posted March 15, 2006 You probably scratched off some of the magnetic surface so it is pretty much trash now. Just record it to your PC and save what you can now. If it is too far gone then it is too far gone I am afraid. One question. How in the world did it get scratched? Did you take off the metal shutter? Quote Link to comment Share on other sites More sharing options...
