fottiti Posted April 2, 2006 Report Share Posted April 2, 2006 Hi everyone! I've just bought a wonderful MZ-RH910. It is really a fine piece of machinery, but it has a little drawback: no LCD on the remote that comes in the bundle. I'd like to replace it, but the RM-MC40ELK is way too expensive. The RM-MC35ELK could be a good alternative, but according to the official SONY chart it is NOT compatible with the MZ-RH910 (or at least it is not mentioned). According to the wonderful guide you have here, though,the RM-MC35ELK is compatible with all 1st and 2nd generation Hi-MDs. Question: can I buy the RM-MC35ELK for my MZ-RH910 and be sure that it will work properly?Thanks everybody. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted April 2, 2006 Report Share Posted April 2, 2006 buy the RM-MC35ELK for my MZ-RH910 and be sure that it will work properly?Yes, go for it. The RM-MC35ELK will work just fine with the MZ-RH910.*thread moved to its appropriate section of the forum Quote Link to comment Share on other sites More sharing options...
raintheory Posted April 2, 2006 Report Share Posted April 2, 2006 (edited) It works fine with my RH10, I would assume with a fair degree of certainty that it would work with the RH910 as well. Edited April 2, 2006 by raintheory Quote Link to comment Share on other sites More sharing options...
