siup Posted April 3, 2006 Report Share Posted April 3, 2006 Hello,I'm new and want to know if it's possible to use Hi-Md Renderer without to install SonicStage?As musician, I use my md only to record in pcm format with a micophone and wanted to upload after that the files in my pc in *.wav.But I don't want to install the heavy sonicstage.. Can we bypass it? How to put the right codec in windows xp used by sonic?Best regardsSiup Quote Link to comment Share on other sites More sharing options...
marcnet Posted April 3, 2006 Report Share Posted April 3, 2006 Hello,I'm new and want to know if it's possible to use Hi-Md Renderer without to install SonicStage?As musician, I use my md only to record in pcm format with a micophone and wanted to upload after that the files in my pc in *.wav.But I don't want to install the heavy sonicstage.. Can we bypass it? How to put the right codec in windows xp used by sonic?Best regardsSiup you can't because:1) The DirectX stuff used by HIMDRenderer is installed when you install SonicStage2) You need SonicStage to upload tracks from the HI-MD device to your PC in .OMA format (be it ATRAC3 OMA or PCM OMA). HIMDRenderer will then convert the resultant .OMA files into .wav, mp3, ogg or flac. Quote Link to comment Share on other sites More sharing options...
