tum-yeto Posted April 4, 2006 Report Share Posted April 4, 2006 hi, my MZ-N710 sony net md walkman is skipping on all my mini discs, it takes ages to load them all up then plays a millisecond then stops, plays anoter millisecond and so on and so on, dont have a clue how to fix this, dont know if its a head cleaning kit i need or what.any help would be appreciated,cheers. Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted April 4, 2006 Report Share Posted April 4, 2006 A head cleaning is where I would start. If you can get an actual head cleaning kit (from www.minidiscaccess.com as an example) use that first. If not you could try a spritz from a can of air then a cleaning with denatured alcohol and a cotton swab made for electronics cleaning (available at Radio Shack). Quote Link to comment Share on other sites More sharing options...
