HELP!
Cantimolto
I recently reformatted and upgraded my computer, but backed up all my recordings of my lessons and things onto an external hard drive. Now SonicStage won't play my old recordings (even the ones imported with SS 3.4 before formatting) because it can't find the copyright information.
Can anyone tell me how to get them to play or show me the thread that might have already addressed this?
Did you use the backup tool? Then restore your files using this tool.
Do you still have them on MD?
If it's no on both questions, I guess you're out of luck. DRM is always applied to uploaded recordings.
One way to strip DRM off of these files (before you reinstall) is by using "SonicStage File Conversion Tool", UNchecking "delete files" and UNchecking "add DRM", or by converting every drm-ed file to the same codec and bitrate and by UNchecking "add DRM"...
