MkBh Posted January 9, 2006 Report Share Posted January 9, 2006 I cannot convert the mp3s into either atrac/atracplus or wav format and whenever i try I recive the message "Cannot convert the specified track." followed by some annoying possible reasons like track cannot be found etc. The error it specifies is (00000908-7209).I have 3.3 version Pls help me solve this issue.I have tried installing and uninstalling time and again but it does not work Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 10, 2006 Report Share Posted January 10, 2006 Are you importing Songs (Mp3`s) via Sonic Stage 3.3 ...You can only get this error if you change the location of mp3 files (folder) in your computer after importing it ..Also It would be better if you can give us a screen capture while gettting this error. Quote Link to comment Share on other sites More sharing options...
MkBh Posted January 10, 2006 Author Report Share Posted January 10, 2006 I have mp3 files in a folder and I add them to sonic stage library and when I click to convert the format of mp3 to atrac it gives the error(track not found, file may be copyright protected or no support for format)I do not change the location of files after importing them in the library. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 11, 2006 Report Share Posted January 11, 2006 Are these mp3 files Copywrite protected???You check this via properties of mp3 file.I `m unable to understand why you getting this error .. Quote Link to comment Share on other sites More sharing options...
MkBh Posted January 11, 2006 Author Report Share Posted January 11, 2006 (edited) I have solved my problem by converting mp3's to wma and then using sonic stage to convert to atrac plus and transfer to psp. Edited January 11, 2006 by MkBh Quote Link to comment Share on other sites More sharing options...
