Sonic Stage Keeps Crashing
super_dude78000
Something about the ID3 tags in Winamp can disagree with SonicStage. See if you can figure out which track is starting the crash--try importing half of them, half of what's left, etc. until you can isolate the track that crashes. Then VIEW FILE INFO in Winamp and try retitling it something simpler--with V1 tags, not V2.
i just applied the patch from here and now it crashes a few seconds after i open it up. i found a way around the whole sonic stage transfer, but now simple burner won't let my rename all of my songs on my minidisk, i transfered the songs in lp4 format so i could put alot of them on.
Edited by Arandrie
