Teralus Posted May 21, 2006 Report Share Posted May 21, 2006 I have had an MZ-RH10 for about 8 months and I love it...tonight I found a mint condition MZ-R909 with all the original box content with 12 MD's, and a MD wallet all for $45 nz (about $20US)...REALLY CHEAP, so I brought it without thinking...nice looking unit and everything....+ all the extras, discs and battery are worth the value anyway...So here's my question:Can I convert tracks to MDLP in SS - then copy the tracks via USB to a disc in my RH-10 formated in MD (I assume the MZ-RH10 can do that)....then use the disc in my MZ-R909 thus avoid having to copy music real time? I would have just tried it but I am waiting for the unit to arrive in the mail. I know 2nd gen Hi-MD can't play old MDLP discs...but can it write them using SS?Cheersp.s. check out the deal I got:http://www.trademe.co.nz/Browse/Listing.aspx?id=57473702 Quote Link to comment Share on other sites More sharing options...
raintheory Posted May 21, 2006 Report Share Posted May 21, 2006 (edited) First off just to clarify, 2nd gen Hi-MD can read MDLP discs just fine. The only thing it can't do is record in the "Legacy" formats (LP2/LP4/MONO/SP) using the recorder itself. Though it can record in the LP/Legacy modes using SonicStage.As long as the disc is a standard MD and formatted to "Net-MD" you should have no problems at all transferring tracks with the RH10 and playing them on any MDLP compatible player.EDIT: Is the MZ-R909 LP compatible? If not, you can still use somicstage to transfer tracks in "Fake-SP" (aptly named because it is actually LP2 quality dressed up to play on SP only players). Edited May 21, 2006 by raintheory Quote Link to comment Share on other sites More sharing options...
Mr_Bass_Man Posted May 21, 2006 Report Share Posted May 21, 2006 The MZ-R909 is NOT a NetMD unit, it can only record digitally via the optical in socket.It is LP capable though.HtH Quote Link to comment Share on other sites More sharing options...
raintheory Posted May 21, 2006 Report Share Posted May 21, 2006 Mr_Bass_Man said: The MZ-R909 is NOT a NetMD unit, it can only record digitally via the optical in socket.Yes but it will play Net-MD recorded content just fine. I think he's wanting to use the RH10 to get the tracks on the discs anyway.I didn't realize the R909 was MDLP, good call Quote Link to comment Share on other sites More sharing options...
Teralus Posted May 21, 2006 Author Report Share Posted May 21, 2006 That sounds good....so I can use the RH-10 to get tracks on....sweet! Quote Link to comment Share on other sites More sharing options...
