dex Otaku Posted May 26, 2006 Report Share Posted May 26, 2006 I can't recall who it was that was talking about the RH10 editing bug, where if you split a track, then delete part of the track, the unit gags .. the problem here isn't really a bug. It's that you have to commit the first edit [i.e. press "STOP"] before doing another.It's likely that other units behave the same way, so - there's your workaround that isn't really a workaround. Quote Link to comment Share on other sites More sharing options...
raintheory Posted May 26, 2006 Report Share Posted May 26, 2006 That may have been something I had mentioned because I had it happen once to me with an important recording. I tried it again with a test recording and was able to replicate it, but haven't attempted anything since.Thanks for the tip/non-workaround, workaround thingy. Quote Link to comment Share on other sites More sharing options...
