Scrambled noise when playing mp3's
evolution100
I had the same problem so I uninstalled SS CP and reinstalled SS 3.4 and I´m having all sorts of problems as I had to go back to SS CP....SS CP is probably the worst piece of software that I´ve come across.....
Maybe this will help you....if you have a mp3 converter try converting the file to another format and see if it plays and then convert it back to mp3...it could be a DRM issue....I used to do that and found that it was a codec problem....unfortunately I´m still trying to find the answer
