Deinel Posted June 21, 2006 Report Share Posted June 21, 2006 (edited) Im a angry man now. Since the release of the SS4.0CP, i have downloaded the installer to install. Yet, while through the process, it just terminated.After that, i had to uninstall and going to regedit to delete all SS stuff. Then i tried installing again. Still no hope!I went on to install SS3.4[(online) i used online installer last time] and it came out with the same problem. So after more than alot of tries, i finally found out where it terminates during the process. Its always occurs when installing the Limited Patch, then it would show this message "Installation for SonicState 4.0 has been terminated. (2051, 20703)."I may think that the numbers at the end of the sentence is a hint as to what i should do to install but i cant think of it!Oh, i prefer to install using the online one as the offline installer doesnt give me an option to install where i want the file to be. Its like they always put in C:\Programe files\Sony.And also, now using the offline SS3.4, it cant read my disc no more, as in it said "Cannot use as audio disc as it is not initialised by SonicStage" or something like that. Darn im super fed up.What should i do!!?Can anybody englightment me, or at least give me anger management course? Edited June 21, 2006 by Deinel Quote Link to comment Share on other sites More sharing options...
Deinel Posted June 22, 2006 Author Report Share Posted June 22, 2006 Cant someone help me? Quote Link to comment Share on other sites More sharing options...
RandomHero Posted June 26, 2006 Report Share Posted June 26, 2006 I'm having the exact same problem. It quits when installing the limited patch and gives me the same error messages. If I find a solution I will be sure to post it here for you. Quote Link to comment Share on other sites More sharing options...
Deinel Posted June 27, 2006 Author Report Share Posted June 27, 2006 Cool, i hope someone come help us real fast. Im going to be enlisted in the army soon and i need to put more songs into my disc! haha Quote Link to comment Share on other sites More sharing options...
A440 Posted June 27, 2006 Report Share Posted June 27, 2006 What usually blocks installation is either firewall and security programs--try turning them off--or lack of disk space. Could either of those be your problem? Quote Link to comment Share on other sites More sharing options...
raintheory Posted June 27, 2006 Report Share Posted June 27, 2006 Also be sure to check your system for Spyware/Visruses (but be sure to turn these programs off before installation). Quote Link to comment Share on other sites More sharing options...
