vmurthy Posted June 22, 2006 Report Share Posted June 22, 2006 Hi, don't yell at me if i sound stupid :-) i have owned MZ NE 410 player for more than 3 years. i have used it for two years and i was very satisfied with its performance and it still works great. the only irritating thing for me now is the 180 MB mini disks. is there a way to use HI-MD disks on my MZ 410 player ? because i am almost on the verge of moving on to ipod. but i love my md player and want to stick with it for atleast some more time provided i can use a HI-MD disk on it. any help is greatly appreciated.thx Quote Link to comment Share on other sites More sharing options...
pata2001 Posted June 22, 2006 Report Share Posted June 22, 2006 (edited) is there a way to use HI-MD disks on my MZ 410 player ?No Edited June 22, 2006 by pata2001 Quote Link to comment Share on other sites More sharing options...
raintheory Posted June 22, 2006 Report Share Posted June 22, 2006 (edited) The 180mb MiniDiscs are the normal MiniDiscs, which should be compatible with all units (except maybe some multi-track recorders which require MD-DATA). Actually they hold more when used with a Hi-MD recorder.The 1GB Hi-MD discs will only work on a Hi-MD recorder. Edited June 22, 2006 by raintheory Quote Link to comment Share on other sites More sharing options...
mestkidd Posted July 5, 2006 Report Share Posted July 5, 2006 mdowner2003,No you can't use HiMD's on your MZN-E410 you will be better off getting a HiMD recorder, it can use HiMD's and normal 180 Mb MD's.Aaron.... Quote Link to comment Share on other sites More sharing options...
