Problem with reading MDs in Sharp MD-831
siem79
Hello,
I face a problem with my MD player. The MD player is turned on successfully, but it cannot read the Mini Discs. It tries to read the Mini Disc and then it always displays the following message in the display screen:
Can'tREADu (at the MD unit device)
Can'tU (at the MD control unit device)
Whatever Mini Disc I enter the same message is appeared in the display screen. I downloaded the user manual and I found that this message means that the disc is damaged. While in my Mini Disc deck all the discs work properly. Could you please provide me a solution or give a hint? Is there any Mini disc which cleans or restart the device?
Your help would be very valuable
Best regards
Andreas
  • 7 months later...
