Cant record on MZ-RH910
Xanzibar
I recently bought my first minidisk player, a MZ-RH910 but I cant record on it. I’ve tried sonic stage (V3) and simple burner (V2), 48 kbps and 64, audio CD’s and MP3s, different discs - no luck. Recording goes OK at first but then it just stops for no apparent reason. The disc certainly isn’t full and the batteries are charged.
When it happens, the Hi-MD window in sonic stage displays the message: cannot use this disc as an audio disc because it was initialised by a program other than sonic stage.
In simple burner it says: cannot continue because files on this disc are being used by another program.
On the player itself I see: cannot record or play.
According to the user manual my only option is to re-format the disc and start again. Most recently this happened half way through recording my 10th CD so over 100 songs recorded before the crash.
I using windows 98 SE.
Any help would be appreciated.
