nousplacidus Posted June 30, 2006 Report Share Posted June 30, 2006 I have my MZ-DH710 working with Ubuntu. It requires Virtualization but VMWare server is really quick with windows if your running an x86.Tutorialenjoy! Quote Link to comment Share on other sites More sharing options...
1kyle Posted June 30, 2006 Report Share Posted June 30, 2006 nousplacidus said: I have my MZ-DH710 working with Ubuntu. It requires Virtualization but VMWare server is really quick with windows if your running an x86.Tutorialenjoy! "Virtualisation" is a great tool for designing/testing Software and using specific Virtual Machines for specific purposes, however running a Windows Guest OS under Vmware on a Linux host doesn't count as a Linux App since you actually have to install Windows and any app ypu want on that Virtual Machine EXACTLY LIKE you were doing a Native Windows install.I'm testing the 32 bit Windows Vista (beta) as a guest OS on Linux If I get any probs Iwon't have hosed up my system as you can then just fire up another VM.The OP was really wanting a NATIVE Linux app.The only thing you can do so far in Linux is use the MD as a pure external Data device but you'll find a usb stick or a camera card in a card reader probably better for that purpose than a minidisc.If Sony ever opens up the format so some sort of SDK is available then I'm sure someone will create some aps.If you have a machine with 1GB of RAM even a modest laptop will allow you to run VM's decently and at near native speed (for Windows XP guest OS you really need a minimum of 512MB RAM to allocate to the guest OS).Cheers-K Quote Link to comment Share on other sites More sharing options...
nousplacidus Posted June 30, 2006 Author Report Share Posted June 30, 2006 Im sure everyone wants a native linux app, but I think we all know that Sony has problems when it comes to their decision making process. The minidisc is an amazing format and I just wanted to help out the less tech savy among us when setting it up with a VM. Happy listening Quote Link to comment Share on other sites More sharing options...
