Live recording from CD to MD
DaveElson
Hi all
Been a fan of MD for some years now and recently purchased a Sony RH-910.
My question isn't regarding how to record live - it's how to make sure those live recordings I do have will transfer to MD without a 2 second gap.
Have to be honest and say I haven't tried it yet with any of them, I'm having fun copying my prog rock onto the numerous older MD's I have - nad so much space (even on those).
Anyway - any advice on this appreciated.
Thanks.
Usually your burning software will have some setting to disable the 2 second gap. In Nero you just check the box:
EDIT, sorry I thought you were talking about burning a CD. You have the live recordings on CD? I am not sure I understand. If the live recordings are on MD they should have no gaps. :blink:
IPB Image
Edited by KrazyIvan
IPB Image
Wow... this is a difficult forum to navigate imho.
KrazyIvan - thanks for taking the trouble to reply.
I was concerned about copying a live cd that had no gaps onto MD.
I did try (after my first post) a live bootleg I had and, it plays fine - no gaps at all so it looks like the software recognises this.
All seems to be well.
Thanks again.
