smkranz Posted July 12, 2006 Report Share Posted July 12, 2006 I've been carrying my recording stuff (MD, mic, phones, remote, batteries, discs) to concerts or on bus/train/plane trips, in a camera bag. It's OK but just...OK.Hopefully this will work out better. It is much flatter to fit more easily in a briefcase, and the stuff inside is much more accessible...I don't have to take everything out to get to the stuff at the bottom.$20 at Target stores. It is Case Logic's "MP3 Player Travel Case", model MPC5.[attachmentid=1858][attachmentid=1859] Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted July 12, 2006 Report Share Posted July 12, 2006 Hey, that is actually kind of nice. I may have to check it out. Quote Link to comment Share on other sites More sharing options...
smkranz Posted July 12, 2006 Author Report Share Posted July 12, 2006 The only thing I would want from this case setup is a little more structure. It is a good size and very convenient, but it is also very soft and squishy. If the front and back covers were a little more rigid, it would also be more protective. Quote Link to comment Share on other sites More sharing options...
Fat Tires Posted July 12, 2006 Report Share Posted July 12, 2006 The only thing I would want from this case setup is a little more structure. It is a good size and very convenient, but it is also very soft and squishy. If the front and back covers were a little more rigid, it would also be more protective. Have you considered cutting open the sides and inserting some type of plexiglass or other harder material then sewing it back up? Maybe a seam ripper would be handy? Quote Link to comment Share on other sites More sharing options...
smkranz Posted July 12, 2006 Author Report Share Posted July 12, 2006 Might be worth considering, though I'll have to look to see whether that can be done without totally destroying it because I don't know whether there is a "lining" into which something more rigid can be inserted. I've found something else online that might be a better option:http://www.caselogic.com/universal_mp3_tra...m?modelid=66180 Quote Link to comment Share on other sites More sharing options...
Fat Tires Posted July 12, 2006 Report Share Posted July 12, 2006 I'm with you. That case looks like an excellent choice for a portable field kit. The only thing better would be a large Otterbox with foam inserts. Quote Link to comment Share on other sites More sharing options...
smkranz Posted July 12, 2006 Author Report Share Posted July 12, 2006 Or, another one like the Quantaray case from Ritz Camera, that I already have for my NH900:http://members.aol.com/smkranz/minidisc/minidisc.htmI could get another of these, but I want something smaller and packable, that will slip into a briefcase or duffle for ease of travel. This thing is a piece of luggage all by itself. Quote Link to comment Share on other sites More sharing options...
smkranz Posted July 21, 2006 Author Report Share Posted July 21, 2006 [attachmentid=1889]This Case Logic MP3 Universal Travel Kit arrived the other day. Looks like I'll have to make something myself if I want it to be *just so*...this one is OK but it is considerably thicker when folded up, than the first case I found above. I will prolly use it...until I see something better.The stretchy elastic pocket on the right-hand side is clearly made for an iPod or smaller player. The RH1 does not fit in it. You can put the minidisk player in the larger (top) mesh pocket on the left-hand side where it is held fairly securely, and use the stretchy elastic pocket for something else like your remote or even some discs. The way it's shown below, it'll even safely hold my PX100 phones...[attachmentid=1895] Quote Link to comment Share on other sites More sharing options...
bobt Posted July 21, 2006 Report Share Posted July 21, 2006 I've used a variety of Kipling bags for camcorder and MD, as well as shoulder bags and back packs. Some of the bigger ones are sei-ridgid, worth a tryKirks down here in Cayman carries them, don't know about the rest of the world$.02Bob Quote Link to comment Share on other sites More sharing options...
