can i reset nwz738f by needle
basit
well thankx alot for firmware link i will update my player i have firmware1.10 installed on it.can i update my walkman with the link u provided hm welll i have another issue that when i try to reset the walkman with any needle does the walkman is prone to scratch or not
5 answers to this question
  Zizone said:
It seems like you found the link:
http://walkman.update.sony.net/fw/pc/ZS730...S730F_V1_11.exe
Anyhow, try installing v.1.11 first then if it does not work try resetting. It's possible to scratch the device (even metal scratches so...) so just don't miss the hole :unsure:
hm well i want to ask that i have a usa mobel nwzs738fb hm i m afraid that installing the aisa firmware might not damage it well sony nwzs738fbmc body is made of metal or is it glavinized
The link I posted is for the US model. To update firmware from 1.10 to 1.11, first download the file to your desktop. Then connect NWZ-S738F to your PC. Once it's connected don't run any program. Then just run the firmware update file you downloaded on your desktop (DO NOT transfer the file you downloaded to your Walkman). The program will run on your PC and update your Walkman that is conneceted to your PC.
About the body of NWZ-S730 series, I am not sure but it is a metal core w/ coating of somesort for its color. It feels like SE W890i phone though, which people say it's metal.
well i have updated my player firmware and now it looks more stable and sounds more good but the battery status is same.though it has stop hanging. thankx alot keep up the good work
