minidisk recorder cheap?
Pirateofthesoul
Minidisc units record better than decently. They will reproduce virtually as good a signal as you put into them. They are slightly quirky but easy to use once you get used to those little quirks.
For maximum music storage you would want to get a Hi-MD unit which will take a 1GB disc and records three times as much information on older minidiscs (74 and 80-minute standard minidiscs).
Best price: MZ-NH700, about $150 Takes an AA battery, so is slightly thicker than some other units.
http://www.minidiscaccess.com/item.html?PRID=1553220
Best features: MZ-RH1, about $330
You're probably talking about an electric instrument? Every minidisc recorder has a line-in jack with a standard stereo miniplug. If you can get a connector from your instrument (or amplifier) to a stereo miniplug, then you should be able to record directly. You may need a simple adapter to change the mono signal from your instrument to a stereo signal and to change the size of the plug.
