Uploading CD records on old MDs to PC using MZ-RH1
azovsky
Hi, everyone! Somebody asked my question already:
"So, let me get this straight...
With this new unit I can finally upload all my old SD recordings. Or can I? Will it allow me to upload music that was originally copied from a CD?
Then once uploaded to my pc - what can I do with the music? Can I convert it to mp3?, wav?, burn it to a CD?, put it back onto SD minidisc?"
But I could not find a clear sraight forward answer. Can I upload my CD records on old MDs to my PC using MZ-RH1? Can they be uploaded in WAV or MP3 or it has to be Sony format? If it has to be Sony format can it be converted to MP3 later? Thanks! :D
Depends on how you got them from CD>MD...
If you used SonicStage or Simpleburner then no.
Otherwise, if you recorded via analog/optical output you should be just fine to upload and convert to WAV.
After that if you really wanted them as mp3 you would have to use a conversion program like dbpoweramp (freeware, avail in downloads section here).
