zachg Posted July 25, 2006 Report Share Posted July 25, 2006 Has anyone used the RH-1 to upload legacy recordings made on non-Sony units? I use a Sharp Md-dr7, and am subsequently wondering if there will be problems uploading content recorded in SP-stereo, and SP-mono on my Sharp unit. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted July 25, 2006 Report Share Posted July 25, 2006 You should not encounter any upload issues (SP recordings) done with non-Sony units. I have uploaded SP recordings (from Sharp SD-NX10) via the RH1 to the PC without any issues. Quote Link to comment Share on other sites More sharing options...
zachg Posted July 25, 2006 Author Report Share Posted July 25, 2006 Thank you. Have you done any mono recordings? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted July 26, 2006 Report Share Posted July 26, 2006 zachg said: Thank you. Have you done any mono recordings?No, I have not. Quote Link to comment Share on other sites More sharing options...
raintheory Posted July 26, 2006 Report Share Posted July 26, 2006 I have uploaded a few MONO recordings. SonicStage converts them to either STEREO Hi-SP or STEREO PCM (depending on how you've set the preferences).Personally I upload SP/MONO as PCM and then convert to FLAC (either STEREO or MONO depending on the source material)... Quote Link to comment Share on other sites More sharing options...
