Question About SonicStage 3.3 File Transfers
Stu-Pid
Hi, sorry if this is question has already been asked, but a quick search didn't return the answer.
As a new owner of a NW-A1000 I quickly discovered that Connect was awful and that SS was the better choice of the two (although 'better' is a very relative word...). Now, my question is whether or not SS has a feature similar to the tick boxes in iTunes? These are the boxes next to each song that you check if you DON'T want the song to be transferred to your iPod when you select auto transfer.
As I've switched from an iPod to the NW, I want to use SS as the DB for all of my music and move away from iTunes, but with 10GB of music and only 6GB of space, I need a way to quickly tag songs that I don't want to be transferred onto my NW. Is there a quick and easy way to do this that I'm currently missing? The only way that I can think of at the moment is to create a 'Walkman Songs' playlist and fill this with all of the music that I want on the NW, and then update and transfer this when I want to add/ remove songs from the NW.
Please tell me that there's an easier way!
Thanks
Welcome to ATRACLife!
SonicStage do not have the "check box" you described for music tracks transfer to your device. (however, the "check box" selection is available if you wish to rip CDs to your library) If you wish to transfer selected music tracks within SonicStage to your device --> from "My Library", you can select the desired tracks by using "ctrl" + the track in question (repeat this step until you have all your desired tracks for transfer) and press the respective "Red" arrow button to initiate the transfer to your device.
