external A/D Aconverter into RH10
Noam
Will the RH10 work with Zefiro InBox/Denecke AD-20 - Dual channel Mic Preamp and analog to digital converter combo? The question has 2 parts:
1) will the RH10 accept digital input and will the SS 3.4 allow to upload it into the SS library and burn discs from it?
2) the HiMD "optical input" is not a regular optical input, it receives a regular RCA 1/8" plug, but the Zefiro has a regular optical output, so I don't know how that works. I basically don't understand how the RH10 line in can double as an optical input.
thanks, Noam
The optical input jack takes a mini TOSLINK plug, which looks like a little finger. Most optical cables purchased at a store will come with an adapter that clips on to the end of the cable, thereby alowing you to go from a regular TOSLINK jack to the 1/8" input on your recorder.
