Uladzislau Posted August 21, 2006 Report Share Posted August 21, 2006 I need help.I've bought a MZ-RH10EE unit recently. As you know it comes with this crappy RM-MC60.I've decided to buy a new one with LCD dislpay. I could only find a RM-MC33L remote. Everything works fine but I CAN'T EDIT TITLES WITH IT!!!!!!!!!!!!!!!! And this is the most important feature for me!!!!!!!!!! I can enter the MENU, can enter the EDIT submenu, but there are only SET GROUPE, GROUPE RELEASE and ERASE options available.Are there some people who own MZ-RH10? Is it normal? May be there are other remotes that have this option available? For example RM-MC35ELK???Or may be I should hack the unit thru service menu? If yes, pls, somebody write me how can I do this!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
bobt Posted August 22, 2006 Report Share Posted August 22, 2006 Go with the RM-40ELKTake care,Bob Quote Link to comment Share on other sites More sharing options...
WaywardTraveller Posted August 22, 2006 Report Share Posted August 22, 2006 Have you set your Menu options from Simple to Advanced? I don't know if this will help, since I don't use the remote for titling tracks or groups...but give it a try.And the RM-40ELK IS the best remote for your RH10 (if you can find it) - just remember to disconnect it if you make live recordings or you might hear some static in the background.peaceWaywardTraveller Quote Link to comment Share on other sites More sharing options...
Uladzislau Posted August 29, 2006 Author Report Share Posted August 29, 2006 Thanx folk for your replyYes, the menu mode is advanced.And what's about RM-RC35ELK? It's Japonize "default" remote.Has anyone actually tried it? I mean title input. Quote Link to comment Share on other sites More sharing options...
