Guest Stuge Posted January 23, 2006 Report Share Posted January 23, 2006 Both the unit loooks wise & Features wise are the same except D-NE006 Has Remote commander & A/c adapter feature ..which D-NE005 doesn`t have .Is there any other Differentiating feature i`m missing .pl tell me Quote Link to comment Share on other sites More sharing options...
0 pata2001 Posted January 24, 2006 Report Share Posted January 24, 2006 I would avoid those units. Not only they are made from obviously cheap plastic, they requies 2(!)AA and their battery life is at the stone age of PCDP. I would get at least the D-NE320/319, which should not be much more expensive than those 2. Quote Link to comment Share on other sites More sharing options...
0 adam917 Posted January 24, 2006 Report Share Posted January 24, 2006 I would avoid those units. Not only they are made from obviously cheap plastic, they requies 2(!)AA and their battery life is at the stone age of PCDP. I would get at least the D-NE320/319, which should not be much more expensive than those 2.Yes. I have an '005 and there's not even an alpha-numeric screen or any way to see what files (or tags) you're listening to besides a total track number & group number. The hissing noise when the unit's volume is high at low passages is very annoying too. This thing shouldn't be higher than 25 USD, if that even. STAY AWAY. I regret spending 42 USD on mine (direct from Sony). Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted January 25, 2006 Report Share Posted January 25, 2006 Yes. I have an '005 and there's not even an alpha-numeric screen or any way to see what files (or tags) you're listening to besides a total track number & group number. The hissing noise when the unit's volume is high at low passages is very annoying too. This thing shouldn't be higher than 25 USD, if that even. STAY AWAY. I regret spending 42 USD on mine (direct from Sony).That`s why I never buy Low end models from Sony . Quote Link to comment Share on other sites More sharing options...
Guest Stuge
3 answers to this question
